- Dec 29, 2013
- Location
- Kidderminster Worcestershire UK
- Mercedes W124 260E M103
As i said , another job on the W124 260E is in the pipe line .My antifreeze is 3 years old , i used Commer G48 last time .And i will be useing it again in April next .. I had problems last time i did this , and it took over 6 months to get the system right . I had this idea of letting the coolant out with the drain on on the side of the block it the part you remove for the pre heater .. It was in a bad possition and i had no room to work on it Also read the people had taken them out ,and trouble was when the part would not go back in .So i removed bottom hose flushed it through 3 or 4 times till only clear water was running out .Drained ithe system again by removing the bottom hose ,.Then i put the right amount of antifreeze in, and topped it up with distiled water. But now i think i have the tool for the job.--i am waiting for it to turn up .
