On Lynall's behalf , no walk in the park job if you have either a lifting frame or a good trolley jack and a 1 foot square piece of thich woodabout 2 inches will do.lynall, is it a difficult job to do?
Symptoms of mine are, sometimes jerky on gear exchanges and there's a very noticeable resonant vibration at 1500-2000rpm.
Is that from the engine bay? I have that too but was thinking it was the exhaust?
have you checked his site? It is a bank holiday weekend, most people are away from work
euromercwebstore
Mine were quite easy, basically jack the car up, stick it on stands lower jack get Ians piece of wood under the sump jack one side of engine, loosen bolts that side jack engine remove mount, fart about lining bolts up lower engine back down and tighten bolts, repeat on other side.
I woke up went outside looked at the sky and thought yep it will be okay, once first mount in my hand the heavens opened, had to keep going as i was doing it on the side of the road so couldnt leave my tools out.
I got wet in place that only get wet when i have a shower
Mine had been weak for some time engine rocked roughly at idle also jerked when going from drive to reverse.
Lynall
I did warn you it was going to rain
euromercwebstore
Lynall
I actually thought of you when i was getting very wet and thinking b#####ks b#####ks, should have listened.
Lynall
I need some engine mounts!! do you have any??
I've got A2022401617/1717 what's your chassis number?
