The throttle on the wifes A190 A class is not responding, car starts and ticks over fine, but will not respond to the accelorater ie, rev up as it should, absolutlely nothing. Any ideas before i get it checked out.
Try leaving just the ignition on for a minute or two before starting the engine........if no success, try disconnecting the battery for 10 minutes or so, doing that might reset whatever is causing the problem. (make sure you have your radio code, if applicable)
