Nox sensor, is A 000 905 008 , superceded A 000 905 9603 sensor 2? Post cat?
What are the first 6 numbers of your Vin?
Without that, there are dozens of different models to check the Part number.
182202, sorry I presumed one would be specific to pre and one to post, thanks for your help :) glc 250d
I don't think those are the first 6 numbers of your Vin?
It should read something like (WDD) 253***
A 253 is a GLC and the next 3 numbers give the exact model.
There are 4 different GLC250D 's
Read the numbers off the lower passenger side windscreen tab or the V5 ownership document.
Just checked all 4 versions of a GLC 250d and the Nox sensor is Post Cat and the Part number I have is
A000 905 98 03 and its priced £362 although that may not me the case since this catalogue was posted.
FYI look at Part numbered 400 in the diagram below and you'll see its post cat.
The sensors above the Cat are the Lambda sensor and two temperature sensors. Part numbers on the diagram 220, 235 and 240.
Sorry was in a rush and thought you said last 6, so it was just habit haha, WDC253
There’s 2 nox sensors bud, I’m after sensor 2 which I believe is 490 on the diagram?
They both look post cat I’m confused, I’m after sensor 2 anyway whichever one that is?
This is the one I thought was sensor 2, and the wires short like the 490 in the diagram? a0009050008, I just don’t want to order the wrong one that’s all , confusing haha
Part 490 is the second Nox sensor, with the same Part number you quoted in Post#1 above
A 00 090 596 03
Sensor 1 is the sensor closest to the engine. Sensor 2 is the downstream oxygen sensor. It is always going to be located after the catalytic converter.
A 00 090 596 03
So nox sensor 2 is the one with the part number I quoted? A 000 905 9603 and A 000 905 00 08? Sorry got awfully confused here
A 00 090 596 03
Didn’t realise there was a table below with listings thought it was just a diagram, thanks for your help on both posts really appreciate it mate :)
