Office shredders
WLeg
London
MB GLC250
Other than cross cut and a reasonable number of sheets, what should I be looking for ? - for a small office <10 users, but loads of old stuff to get rid off....
Is this a good deal ?
if you have loads of stuff to dispose of have you considered the national shredding firm SHREDIT ? www.shredit.co.uk they turn up in a big truck and shred everything while you wait & give you a destruction certificate - they lob in archive boxes , lever arch files incl the metal bits and staples are not an issue. cost about £60 or so a time but well worth ot in my opinion. I'ved used them a few times when clearing out old files at each year end eg over 7 years old etc. To be honest the little one will probably drive you nuts as they tend to only take 2 or 3 pages a time and for a big job will overheat & cut out often ( from my experience anyway :) )
I've got one like the eBay one. It's fairly new, but seems OK so far. I recently bought it to replace my second smaller Fellowes shredder. Both the previous ones broke - the gears are nylon, and they strip after a while.
I've not taken this one to bits to confrim, but I think the gears are abs or alloy, so should last better.
PJ
The link on eBay above is really a personal shredder, the office ones are a bit more manly than that.
I have a Rexel unit that takes 11 pages at a time, CD's, credit cards, staples, paper clips and even that needs a good clean once a week just on daily general use.
I've got a slightly bigger version of this which also crosscut (due to me dealing with peoples credit card details).
REXEL P270
This is a decent office shredder...remember these are big items, they will sit nearly the height of desk from floor level.
REXEL P335
Small shredders are OK for small amounts of stuff. They will only take a few sheets at a time. They will cut out if overworked. Cross cut shredders have to work harder.
If you have a lot of stuff go with a shredding service to get rid of it and then work out what size of shredder you need to keep up with getting rid of stuff as needed thereafter.
I have a Fellowes small office shredder, bit like that eBay one but with a few more features. Will take anything, stapled documents, has a CD/DVD slot which will also destroy credit cards which is useful.
Remember to lube it up every month though. ;)
