haggis0073
Good idea, and i can then monitor the leak to see how bad it isMine were leaking enough on one side only to very occasional drip onto one of the exhaust shields.
I didn't fancy doing the whole reseal for such a minor leak so just cleaned up the area really well and run a bead of high temperature silicone sealant (Silcoset 158) around the edge which has been fine for a year. When it starts again I'll remove the cover and do it properly.
You'll also most likely need to replace the bolts if they are alloy with stainless due to them being so soft.
