Hi Greedy,
This was a private sale, and to be fair to the guy everything he said was true and it was a good price. He was selling on behalf of his son who moved abroad and the car had very little use the past 2 years, just sat in his garage. The service history stacks up each year and has had the AT filter / fluid done at 80,000 which was a good sign.
Most motors I have had the temp gets up to about 83c so on the test drive the temp I was getting didn't seem out of reasonable expectations. The burst brake pipe was a bit of a shock but luckily I found the cause. Unfortunately these modern vehicles have so much plastic covering everything that when buying it is not viable to have a full look about behind everything. Even the MOT misses many of these issues.
Fortunately I am fairly confident at DIY mechanics and so have most tools needed and to be honest tackling these issues now is peace of mind and has given me the opportunity to get to know the vehicle a little. Tackling the jobs myself saves a lot of money that I then use for other maintenance items as a precaution. So far I have installed carplay, done oil change / filter,
fuel filter,
cabin filter, PCV, thermostat, turbo inlet gaskets, brake fluid flush and soon to do
power steering flush.
My only concern is what the EGR tract holds as I am aware these things gunk up over time. Further down the line I envisage inlet removal and clean / swirl flap delete with
oil cooler seals done whilst I am in there.
