boxer 01
- Oct 23, 2009
- w211 e320cdi sport g7 with paddleshift
Hi my W211 has developed a weird fault, when car is stationary and revs applied engine revs ok but as soon as you take your foot off the pedal theres a vibration and a growling noise which didn't exist before. I plugged in an obd scanner and 3 faults showed.
P2237- power train (current fault)
2) O2 sensor positive current control circuit/open bank 1 sensor 1.
P2A00 -power train (current fault)
O2 sensor circuit range/performance bank 1 sensor 1
P2664 - power train
B rocker arm actuator control circuit high bank 2.
As I am at work I haven't really had chance to do any in depth investigation. But I checked the the oil level and it was on max. Which when I did a service a couple of weeks back was halfway on dipstick, so I'm assuming whatever is faulty has caused my oil level to rise. Can a faulty O2 sensor cause the oil level to rise maybe overfueling. Any help would be appreciated.
P2664 - power train
