I have a strange problem with the OM642 V6 CDI in our Vito, which is occasionally reluctant to start when hot. It turns over very slowly, just as if the battery was flat. But once cooled down it turns over at a more normal speed and starts fine. It only does it now and again, but today I was stuck somewhere for 30 minutes and about to call the AA out when it finally started! I drove home again (same 16 mile route), left it 5 minutes, and it restarted without any problem. It definitely seems to be heat-related in some way as cold starts are always fine ... this can only apply to something in the engine bay as the battery is under the passenger seat.
The garage took the battery out and tested it at the last service, checked the terminals and earth strap, and couldn't find any problem. One possibility they mentioned was a 'lazy starter motor'. I'd not heard of this before, but from a quick Google it does seem to be a 'thing'. They said they replaced quite a few on BMWs in particular, but were reluctant to change mine as they couldn't guarantee it would be an improvement.
After today's incident I'm inclined to replace the battery anyway as it is 16 years old now and has covered 160k miles. This can't hurt and might improve things. My only other thought was that the engine could perhaps be low on compression when cold (making it easier for a slightly weak battery to turn over), but most of the time it does restart fine when hot. Of course an engine is normally harder to turn over when cold.
Any other thoughts?
TIA
Any other thoughts?
TIA
