Hi guys, my C320 W204 with the om642 engine has developed a misfire on cylinder 6. She is knocking/clicking loudly and won’t idle properly its at 600rpm. I have replaced the injector that didn’t work and then the turbo because the vanes were seized and strangely pushing them down made the knock disappear? I have had star plugged im now and it’s said ‘number of combustion misfires at cylinder 6 too high’ and ‘check component N10/1kn relay which i have worked out is the fuel pump relay. It also basically said to test wiring between SAM and the ECU. Whilst I await a relay i am just curious what are people’s opinions about what this problem could be and what i should be looking at as im not convinced it is the relay. Cheers
