Hi all. I have a leak down the back somewhere. It is engine oil. The top of the block looked dry where the fuel filter is, but I can't even get an endoscope at the back. It's a 2013 R350 CDI with 100K miles.
I swapped the read seals and that isn't leaking. I've replaced the PCV.
Had another look for oil today and the turbo inlet was wet with some oil. I idly put my finger on the shaft and it's loose. Lateral play The impeller is not touching the housing, but I wouldn't want to try any feelergauge in there! It's that close. There has been no noise and MPG and power are good. I guess 100K and 18,000 mile oil changes are to be blamed.
So I think a core is the way forward?
The look for leaks once its off?
Wobbly turbo
Wobbly turbo
