OM642 stop while warm up, then engine crank, not start,
Josakya
malaysia
ML280 CDI
HI All, good morning,
just bought an old ML280 CDI, 180,000 miles mileage, and it was okay until I brought it back home.
After 3 days of parking, I tried to warm up the engine, and after 5 minutes, the engine died suddenly. After cranking the engine for a few times, about 10 times, it does not start.
The suspect fuel tank was empty. Then, about 10 liters were filled. The engine cranked a few times, but it didn't start at all until the battery lost its voltage.
Can anyone advise?
The vehicle was running OK until it ran out of fuel.
You will probably have drawn air into the diesel fuel system.
Charge the battery and try again.
The air lock will probably clear.
If not, you will have to bleed the air out of the diesel fuel system.
As johnaco say it will will have air in the system as the tank was empty
So Josakya ...
Did you cure the problem ... and How ?
So Josakya ...
HI Johnsco, i still couldnt start the car, mechanic came to jump start the engine but failed, he tried to check the fault codes, but that scanner couldn't make connection means no data at all.
i took out the gateway module, open it, looks ok, no corrosion. wire connection also looks fine.
Did you buy the car from a trader, or in a private sale?
Likely to be a fuel problem as suggested, but as an aside a failed crankshaft position sensor will give the same symptoms (cranking without firing at all).
