Hi all, I'm new to this forum so just a quick hello before getting on with my first post
Was searching for info on leaks from the oil cooler housing as got a very small leak developing in what look likes the location directly behind the plastic oil filter housing where two transfer oil guides locate with the engine casing, so was initially thinking of ordering a couple of packings (A0199970445 & A0199970545) to replace the ones on this plastic housing, but then came across this video on youtube which details an oil leak from the oil cooler housing check valve seal, which sits directly above the transfer oil guides, so my leak could be coming from there not the transfer oil guides.....
Mercedes OM651: Engine oil cooler check valve gasket replacement
Further reading lead me to this post from last year, which also details an oil leak from the oil cooler check valve (thermostat housing?).........
OM651 oil leaks - oil cooler | Engine
After a quick search of MB parts lists, it does not look like the check valve seal is a procurable item on its own as it is not shown as a broken out part. Before I start pulling bits off the engine, I'd like to get all the parts in hand, so my question is, does anyone know if this seal can be procured separately and if so, what the part number is? Or alternatively the dimensions (ID, OD & Cross Section) of the seal so one can bought?
