- Oct 4, 2019
- Location
- Guildford
- E250 Avantgarde Estate, Alfa GTV V6, Vespa, Ducati, many bicycles...
Hello all
My S212 E250 is certainly wanting some attention from me at the moment! Apart from a normal B service its had a trans cooler and water separator(?) and im about to replace the DPF pressure sensor which the iCarsoft found a fault with.
However, for a while i have intermittently had a problem losing power steering, and it seemed to coincide with splashing through (not deep) puddles. I thought it might be a case of the belt slipping but nothing else was coming up with any fault codes, and to be honest it seemed unlikely as the belt isn't really near a particular splash zone that i could tell. However today i definitely heard a small squeak after a momentary loss in the rain, so assume it must be the belt slipping slightly.
So my question is - is adjusting the tension quite straightforward or does it need to have some critical tension? Also, would it be worth getting the belt changed/idler/tensioner changed? I read somewhere that a slipping belt can indicate impending doom!
Im off to the NL in it next month so trying to sort these niggles.
Thanks!
Thanks!
