Soooo. After relentless attempts of solving the issue of engine light flashing resulted in limp mode being activated, 3 garages trying different things to no avail! I had a Mercedes’ specialist let lose and after changing the boost pressure sensor and then noticing there no power going to this, he took the plugs of ecu and hardwired to the sensor and got a current so Diagnosed it as a faulty ecu? My question is two things… would the ecu stop sending signals to this said sensor while it’s in limp mode and that’s why there’s no power? And if this is a faulty ecu what would be the best solution to the fix? New ecu is going to be expensive, and I’m under impression a second hand one would not work by simply swapping it over?
