webberjim17
Hi All,
I appreciate any help.
C Class c250cdi 2013 (W204)
Car is in limp mode, P0101 fault code. I have replaced an air-intake hose as it had a very tiny pin-hole, but I cannot get the fault code to clear. When I re-set it and run the check again before the engine re-starts, the fault still shows.
When I clear the fault and start the car, the EML has gone but th car still won't rev above 2,500rpm.
Do i need to do any further adaptions etc to tell the car that I have fixed the likely fault? Or is there likely to be an additional fault that is being picked up, even without the engine running?
I am using Icarsoft MB V3.0
Many Thanks.
Many Thanks.
