Lyserman
Well after thinking the O2 sensor issues were sorted, the first time I drove it from cold the EML came back on, P0137.
I have changed all the usual things, vac hose and check valve under the inlet manifold. ECU re-flashed. Even renewed the pipe and check valve that feeds the evaporative system as that check valve had stopped functioning. No sign of oil contamination in the loom.
So today I am removing the starter motor and other ancilliary bits to check the wiring loom from the downstream sensor back up.
Any further suggestions from the audience would be most appreciated?
Thanks,
Tony
Thanks,
Tony
