Hi new to this group, I am having a similar problem with my car E350e 2017, fault with the rear right parking brake
“Rear right parking brake has a malfunction. There is a short circuit to ground”
I have changed the brake actuator and caliper but still the same issue, check the wiring to the actuator under the wheel arch and also the 3 fuse used for ABS, there is no power going to the actuator on the driver side rear, are the rear brakes powered independently or is there any control unit I can have a look at. Thank you in advance
