Phone in a CL 600
maxg
CL 600
The Nokia phone in my CL 600 (2002) is no good with the network I am on, I was wondering is it a big job to change it to a blue tooth receiver.
Does any one know.......:o
A Bluetooth hands-free enabled phone or device will make no difference if the Cellular network coverage is bad where you are. Normally a built-in phone (with an external antenna) should be superior to a separate hand held unit inside your car.
Question: Do you get better signal strength when you put the SIM-card in another phone inside the car?
There could of course be a hardware failure in the Nokia phone. OR if the phone cradle has a connection to an external antenna: There could be bad connection.
Before going mad all over the phone, I suggest that the coax cable harness (if your Nokia phone cradle has this feature) should be checked.
maxg said:
Yes sorry should have made it clear. The phone I have unlocked but does not work with 3 network. Any idears..:confused:
it would be cheaper to move network than start and change bits in the car.
We didn't win the war with that attitude.........;)
Any other suggestions.
I had the same problems,and have the same cradle,vodaphone worked fine but 02 did not work,Virgin worked but no steering wheel use.
Malcolm
Where I live is "3" a UMTS operator. Remember that GSM and UMTS phones behave differently and could give very different results when compared. Do also bear in mind that the operators may not share the same antenna sites. Operator "A" may give superior results with a small handy inside the vehicle, while operator "B" may not have a favourable site just where the vehicle is positioned during the test. The only comparisation that could really be made is moving the SIM card between different phones assuming same operator all the time. The propagation on these frequencies depends very much on reflections and also absorbtion that for instance is quite high in vehicles equipped with infra red heat protection (Thin metal layer on the wind screen). Therefore if the base station is in the front of the car and a handy is used inside - don't expect to get good signal strength. Portable GPS navgators with internal antennas will not work very well on the dash board either. Therefore my recommendation is to always use an external antenna "shark fin" on hidden in the pattern of the rear window.
I am looking to change the cradle in the car. With hopefully a blue tooth type fitting. The car has a good arial in built into the rear window and in one of the pillers. So the reception should not be a problem.
Re Merc kits, is depends if you now have a cradle (fitted to an edge connector in the armrest)- call UHI - or a cradle with a curly cable - which means you are in the poo.
Which do you have?
Which do you have?
Deep deep POOOOOO :mad:
Any way out :)
Yes, either stay with the phone you have or fit an aftermarket kit and forget about dash/steering wheel integration.
Parrott are good and support a whole raft of the sort of phones/PDAs/Blackberries you want to be able to use! (instead of a few square Nokias).
Is there any way of converting it from poo to UHI (to take moden hand sets)
In theory yes. Requires much £££££s and the car taken to bits. Not usually cost effective.
Quite a common question on here and I can't offhand remember anyone actually doing it??
I would take a glance at the (short) list of phones supported on Merc bluetooth first - needs to be:
a) SAP (SIM Access Profile) capable
b) on Mercs supported list (or its at your risk that it works/continues to work).
Have a look here:
http://www.mb-accessories.net/mba/index.php?dyncnf=mba#
(also covers the cradles and supported click-in phones alongside the Bluetooth list).
The dealers have another list that also lists the firmware levels in each model that they support - any other levels and they will not look at problems.
There are no sexy PDAs etc on either list (and no Blackberries).
Never thought that Benz would support new phones in my old ´00 CL...
