Placement of 12v supply socket in boot of my W176
Dave Richardson
Plymstock Plymouth
W176 A class 180 cdi
I didn't have a 12v supply socket in the boot of my car so decided to fit one using parts purchased from E Bay for under a tenner.
Bought a fused socket, piggy back fuse & a length of suitable cable. I drilled a 22mm hole in the side trim & fitted the socket & cable through the hole, then fed the wire behind the trim panel & lower door step trim to the fuse box in the passenger footwell, finally connecting up the supply to the existing ignition fed supply for the front 12v socket. Easy & only took just over an hour
Finally sitting in the Devon sunshine to enjoy a glass of this locally brewed ale.:)DSCN1736-min.jpg
