minhazmitha
Hi everyone,
I’m having an issue with my W205 C-Class 250d and hoping for some advice.
It all started when the AdBlue warning light came on. I was told the NOx sensor needed replacing. Around the same time, the DPF light also appeared, indicating the DPF was clogged. I took the car on the motorway to do a regen, but while driving and revving around 3000 rpm, I noticed that after about 20 minutes, the car suddenly lost power. It definitely wasn’t pulling as it used to.
To deal with the issue, I had an AdBlue delete and DPF delete done. Later on, I changed the exhaust sensor, which made a small difference but didn’t fully restore the power.
Now, the car still feels underpowered and the engine sounds louder than usual. I was told that after the AdBlue delete, the garage should have re-tuned the ECU to properly distribute power. Could the lack of an ECU re-tune be causing the power loss?
I’m wondering if anyone else has experienced this or knows what might be causing the reduced power? Any insights or suggestions would be greatly appreciated!
Thanks in advance!
Thanks in advance!
