PPF
RBJB29
Lincoln
E53 coupe
Looking for a bit of help as getting mixed messages.
Can, or should you put ceramic coating over PPF?
Any help appreciated and grateful for any responses.
Ceramic coating is very hard and PPF is (generally) sacrificial. I would imaging the ceramic coating would craze if it adheres at all.
No point
I assume your intention is to increase the lifespan of your Paint Protection Film by applying a ceramic coating over the top of it. The greatest degradation of PPF comes from sunlight which will cause the clear plastic film to become brittle and yellow over time. You will need a specialist ceramic coating with a high concentration of UVA and UVB blockers. Have a look at CarPro CQuartz Skin. It will cost you around £65 for 50ml:
CarPro CQuartz SKIN PPF and Vinyl Wrap Coating 50ml - Elite Car Care
I had front end PPF installed and then ceramic coating over the whole car including the PPF. If anything it acts as a double barrier and I don't believe PPF has the same hydrophobic effect as a ceramic coating has. So in my opinion (and the detailers that I spoke to), yes it can be a good idea to put a ceramic coating over PPF.
Below is the product that was used on my car. I'm not selling it as the best out there, I'm simply posting it's claimed benefits.
Krypton 5 is a permanent ceramic paint coating that features a High Gloss, which is Scratch Resistant, Chemical Resistant, UV Resistant, Thermal Resistant and Anti-Graffiti.
Krypton 5 has a Super Hydrophobic and Anti-Graffiti effect combined mean the 5H coated surface will stay cleaner for longer, as dirt and grime will not stick to the surface and the hydrophobic effect of the coating will cause water to bead up and roll of the surface with any dirt and grime, the hard ceramic film also offers superior protection from damaging contamination and harsh chemicals.
Krypton 5 forms a permanent bond to the paint work and will not wash away or break down, can only be removed by abrasion making it a highly durable protective coating to protect your paint work for damaging contaminants.
The unique formulation of Krypton 5 has enabled it to be multi-layered which means the thickness of the coating can be increased with additional layers allowing a thicker / harder film that will increase its scratch resistance. This can be an additional service at a fraction of the original cost after the detail has been carried out.
Many thanks for the replies, guess there are options both ways which in a way is reassuring.
Thanks again
Gtechniq will be launching a product called 'HALO' which will be for PPF, satin, vinyl and matte surfaces so hopefully your local accredited detailer should have you safely protected.
  • Like
Reactions: Yex
