First post and my first Mercedes.
So i recently bought a 1998 c200 elegance, and it wont lock or otherwise react as it should with a working pse. I can only hear ticking sounds from what i presume is the relay in the pse, no humming or anything.
I have disassembled the pse and the motor have some small signs of burns, but nothing big.
My problem or confusion began when searching the part number found on the pse, not only is it rare, but a tad expensive as well, but the cars that it is listed as origin and fitment are completely different models.
And it is a sticker on my pse that makes me think it is not the pump that originally came in my car.
The previous owner had it parked for 4years because it ran in limp mode,
something i think is because of low trans oil. (its not limping anymore)
The central lock worked just fine when it was parked, but after a while he wanted to move the car, but with a flat battery he drilled into the trunk lock and managed to open it.
So my question is as follows:
Is there more than one part number that will fit, with nothing more than maybe star coding?
What is the correct number to the pse that should be in my car?
I want to try to connect the motor directly to current to see if it works, what voltage should i use?
Do someone here know what pins to connect just to test the whole pse and its different functions? 12v?
All help is greatly appreciated!
