SkegVegas
2006 R500 with brake lights on all the time the ignition is on. The ABS module is recognising the brake pedal position.
We have disconnected the trailer wiring from the car. Replaced the rear SAM with a new one from Mercedes. Still the same. It only has a single filament bulb for tail and stop. The rear SAM increases the voltage. All stop lights including the high level are on. Checked the rear wiring loom from SAM to rear lights. It is only showing one code in rear SAM, The lnput of circuit 54 has a short to positive. 909A this is a hard and stored code.
Any help especially on circuit 54 or on how the rear SAM gets its command to operate the stop lamps gratefully received.
