Biglee
- Oct 6, 2013
- Location
- West Yorks
- 500 SL & Lexus IS F Sport, Land Rover Ser 2a & Saab Conv
Anyone have any tips on where to start investigating non functioning remote CL. It use to work fine and from quite a distance. Was left a few months and when went to use no remote. So I changed the batteries in the fob. Also I changed the batteries in the second spare fob.
Batteries in both fobs now OK . Tell tale light comes on in fob if you hold down for a few seconds. Fobs are emitting IR as can be seen when pointing at phone and taking a video.
Central locking works fine and all red and green lights in door and boot work fine, when using the key. Lights flash when using the key manually.
When you use key and hold (for example when keeping key turned when locking to allow windows to close red lights flash. If you press fob whilst it is doing that the flashing changes slightly as though the car recognises that the fob has been pressed.
I have tried every re sync procedure I can find - EG 1 point and unlock ( as per manual) and also all of these : Synchronising one-button infra-red flip keys to the car
But still nothing. When I press fob nothing registers.
I have disconnected battery and left. Left key in ignition for hours. Also removed connector from control unit in boot and reseated (just to make sure). I believe the controller units are coded to the car, so cant just try a replacement from a 2nd hand car.
The fuse in the boot for cent locking (shares boot light) is OK and all other fuses have been checked.
Can you still get any of the replacement systems that converted to Radio remote and any experience of those. Do they still flash red/greenlights ?
I would really like to get the remote CL working on orig IR if possible. This is early system with nothing in the rear view mirror.
Appreciate any input to my problem. Thanks Lee
