R129 - plastic corrugated pipe protection disintegrated
R129mine
Buckinghamshire
R129 SL500 from 96
Hi
Does anyone know what this pipe is for and if I can get some replacement corrugated pipe protection. I circled in red
The plastic pipe cover is just integration on touch.
Many thanks
Hi
Many thanks
The cable the pipe "protects" is the output from the alternator, so it needs a bit of protection given the way the cable is routed.
Mine has disintegrated too: It's on my "to do list".
Kind regards,
Kind regards,
Thanks. I thought it led to behind the alternator. Just purchased this from Amazon. It is 5mm on the inside which I think matches it perfectly. https://amzn.eu/d/dPxvYsz
It comes in silly length so I will have a few spare meters. I can post some to you if it works afterwards :-)
Replaced the corrugated pipe with a 15mm one from Amazon, ofcourse now the blue jaw clamps all broke into a million pieces, i have one good one left, it is blue, I cannot figure out which part this is, looked on the MB parts website online but could not find the correct category
I did find a few candidates, as the corrugated pipe is 15mm i think 15mm or 17mm clamp will work okay, the sl shop have these available and i think the most right one is 15mm so that should fit, the original ones are kind of oval shaped.
I mean i could zip time them also
Filthy job to do btw, my engine bay is pretty clean but this is all in areas of the engine bay I have not had the pleasure of working in before and it needs a good degrease!!
All fixed. Expensive clips but slshop helped identify them for me. Another small job ticked off the list IMG_5560.jpegIMG_5554.jpegIMG_5558.jpeg
