Sbryantgb
2000 R170 SLK 200 Kompressor
Gearbox will not shift beyond 1st (Limp mode). This happened directly after having run the car through an automatic car wash. (Which also performed an underbody wash)
B-3020-Body
P0220- Powertrain
The above codes are from the OBD connector using Torque Pro.I have looked up both and also read as many posts and threads that I can find, but I'm wondering if the issue might be moisture in the Mercedes Transmission 13-Pin Connector?
B-3020-Body
P0220- Powertrain
