Pipemaster
I have been trying very hard not to bother people on the forum about yet another PSE issue BUT I am stumped
Sl350 2007 pump was operating then stopped. Impeller was broken so changed that. Pump worked again but only after the car had run and once left the locks became inoperative.
So I changed the pump. Same thing. The I sent the whole thing away to be refurbed after I was told the impeller wasn't fitted properly, the motor wasn't powerful enough to get the required pressure and one "duo" was blown. I have got the thing back fitted it, took out the 20amp fuse and replaced it too for good measure. Sat in the car turned it on and then off again. went to lock the car nothing however sitting in the car i pressed the dashboard mounted locking button and the doors operated but then i noticed they work working the opposite of what they should i.e. when i pressed the open padlock button the doors locked. This is obviously because something is the wrong way around. The boot doesnt open either. I have charged the accessory battery and tested it it is fine.
The roof operates properly.
is there an electrical plug that may be the wrong way around? Should I drive the car for a while to "let is settle down".
I really don't understand why this has gone the way it has considering that the the thing was OK before the impeller broke up.
Advice happily received
Thanks in advance
Steve
Thanks in advance
Steve
