PPC
- Nov 30, 2022
- Location
- Somerset
- Current Toys: S63 Coupe, R230 SL350, (Sadly gone: R129 SL320, R231 SL350, ML350)
So I have a 2007 Sl350 that was picked up as a stop gap car. it not used much like many SL's. I used to use a Noco Genus 10 charger to keep the front battery up to charge and that worked fine. However, I had to sort out a little bit of rust in the boot so pulled out the Aux battery and did that work. Once I popped everything back in I put some charger terminals onto the aux battery and started to see a very odd behaviour.
The car trickle charges for a few days but then either records a battery short or just seems to run the battery flat. The remote goes dead so I have to open the car with the key manually. Then I start the car and everything seems to spring to life. The battery charger then seems to say : Oh hang on! no I am not completely flat I am actually green! look see? and then starts behaving normally until it repeats the saga all over again.
If I run the car it starts with the usual AUX battery is dead error but once I have run 20 miles or more and give it a good cycle all the batteries read 12v+ and everything goes back to ok.
Has anyone seen anything similar? I should say that I have an S Coupe that I share the charger with and it works perfectly ok on that.
