R500's new battery.
milleplod
Bolsover,no longer home of The Beast!
S212 E350CDi
I've just bought a new battery for my R500 - big, heavy and expensive, but the original's lasted 10 years, so hopefully this Duracell one will do the job for a fair while.
Quick question. The original has a vent pipe, the replacement doesn't. Is it the case that some need a pipe, some don't.....or will I die horribly when the replacement explodes because 'you should have got one with a vent pipe'.......?! :eek:
Pete
You will die horribly.
Or maybe not.
If it doesn't have a visible vent then it doesn't need one.
Not a gel or agm type is it?
Then it doesn't need a vent pipe. Under normal circumstances they don't gas.
If the vehicle overcharges they will gas, and iirc any venting is done via a valve in the lid.
