design guru
- Feb 28, 2004
- Location
- Hampshire
- 2001 W220 Mercedes S320cdi & 2001 W208 CLK230K (SORN since 2008)
I have an S320cdi on a 2001 plate(51)
The car runs fine and all the electrics work fine, but on the odd occasion it will play up and not just one problem, its all of them!
On the odd occasion the ESP, BAS, ABS lights will flag an error and advise me on the computer it needs workshop attention and the cruise control will fail to work, but this happens once in a while. Usually when I turn the key to position 2 before starting the engine and the glow plug light does not go off.
I do need to change the glow plugs anyway but the light usually goes off and then comes on again after a few minutes of the engine running.
During all the warnings the car will still drive as normal but keep in the memory that there are faults that need attention.
It sounds like the star machine would be the obvious diagnostic route to find the problem but has anyone experienced a similar issue?
Often shutting the car down and restarting resolved the problem on one occasion.
