HairyBreeks
Hi All,
I have a range of odd electrical issues on my 2010 e250 cgi and hoping someone with electrical knowledge can give me a few pointers..
The issues are all intermittent and never show any messages on the dash - things like;
My car does not have an AUX battery, and the main battery has been replaced, and I've checked there is good charge from the alternator.
My question is - Is there a way to track this sort of thing? An MB indy reported no fault codes showing up so that seems a dead end.
Would intermittent things like this usually give a code, and if not where does one start in trying to track the source of the issue down? SAMS unit replacement?
The earthing points I can find look ok and I cant see any damage / corrosion to visible wiring.
The alternator has had a oil leak into it in the past, however is charging the battery fine. (steady 14.4v when engine running - occasionally spikes up to 14.9v which I've read is normal).
Or is it a case of auction the car, accept the loss and move on!
Many thanks in advance
- Windows stuttering or stopping (when holding button constantly a single direction)
- All speakers cutting out completely. Turning stereo off and on makes them work again
- FM radio signals all disappearing - then reappearing (FM amplifier cutting in an out basically)
- Key sometimes has no effect (car wont crank) - then starts working again.
