Removing Dashboard in W124.
Timster
Scottish Borders
Currently Merc' Less.
Hi.
I posted last week as I keep blowing a fuse. I’ve traced the problem, and think it’s the wiring behind the dashboard, so I need to remove the dash, and replace a bulb and check the wiring there.
Question: Can I remove the dash without taking off the steering wheel and whole front console, as suggested in Haynes, and I’ve heard rumours that there is a special tool for removing the dash, like the ones you get for car stereo’s. Is this true, if so where do I buy, borrow one from.
Just to put you in the picture, I’ve just had this car a month, and am trying to restore it to it’s former glory. Mechanically absolutely sound, just requiring a bit of TLC on the electrics! It’s a W124 Estate (250TD 1987 model.)
i assume you mean the instrument cluster?
if so you need one of the tools as shown in the link below (or make one from a coathanger):
http://www.poundhost.com/mbclub-file/sym/cluster3.htm
i've never had to remove the cluster from my W124's but on my CLK (W208) i managed to get it out by pushing from behind by reaching up under the steering wheel - but i dont know if you can do that on a 124 due to the design of it.
As per Silver Saloon.
Just reach behind from below and give it a shove and it'll come out. Less chance of damaging anything than with coat hangers.
Someone must have very small hands and arms or half your heating and wiring is missing. :crazy: Attempted this on mine last night, as an experiment during the course of steering column swap. No way Jose. Resorted to the tools :( On mine the heater trunking gets in the way.
I just remove the lower foot lever surround panel (3 bolts IIRC) and then its easy access on the rhs.
