gbCambridge
- Apr 7, 2014
- B250e
I have owned my 250e for about 6 months and I am still discovering "features" in the SatNav and Cruise logic. Here is something that I just found...it seems like a fault..but you tell me.
Assume that you have set up SatNav for a journey and that you are using cruise control. At a point on the road, the SatNav tells you to take the next exit, where the exit road meets a roundabout, and where you should take a certain exit (which one does not matter).
Now let's assume that you know better and decide to drive straight on. What appears to happen is that the SatNav is not aware of this decision and goes through the motions as if you had taken the exit, which involves slowing the car down and twitching the steering for roundabout crossing. This can be a bit disconcerting for cars following as they see no need for you to slow down.
I have not tested my solution yet, but it involves disconnecting the cruise when I decide to ignore road instructions and reconnecting it when the exit (or whatever) has passed.
So, is this a bug or a "feature", and in either case where in Mercedes do such things get reported?
