Spinal
- Sep 14, 2004
- Location
- between Uxbridge and the Alps
- x254, G350, Duster, S320, Mach1, 900ss and a few more
Well, today I popped by a bike MoT garage to get my new MoT. Lo and behold, after mentioning on another thread that its an Italian bike AND I've never had ANY electrical problems with it... well... MoT failed... grumble... Nothing too serious luckily...
Point 1: Dipped Beam lights does not work
fair enough, I didn't realise motobikes had 3 light levels. I thought they only had 2. Tomorrow I will open the headlamp and check the bulb. (The "parking" and "high" beams work though.
Point 2: Nut on the brake lever (the one that you use to adjust the "slack in the cable") is missing. Another fair enough. I didn't even realise there was a nut on that bolt; I got the bike that way, but I'll shove a nut on that tomorrow.
Point 3: Indicators flash at more than 120 times per minute.
Hmm, haven't bothered measuring this one. I didn't know this was an issue either. Now, short of changing the relay; I had a quick look through the manual, then I remembered that the rear indicators were replaced by the previous owner. my guess is that the 2 rear indicators are a different resistance from the original ones, and hence cause this issue.
So I was thinking a quick and easy fix would be to find a different wattage bulb... (1/2 watts more or less). Problem is, I don't remeber my physics that well
Do I need a slightly higher or lower resistance bulb? Or should I skip that altogether and just hunt for a new relay that will cater for the new indicators?
Michele
p.s. What happened here about 15 minutes ago? The forum seemed unreachable... hmmm...
![Stick Out Tongue :p :p](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f61b.png)
Michele
