Retrofitting
k3vb
London
2006 w203 c180k coupe
Hey guys my sister has a 2002 w203 c180k sports coupe and was wondering what can be retrofitted to it from a 2005 w208 clk200
Sorry, I can be of no help to you. Perhaps the lack of response may indicate that nothing can be fitted, or that that most things can be fitted. Perhaps a question about a specific part might help.:)
I think the clk was a 209 not a 208. You'd have to put down more information about both cars and what kind of things you want to retrofit. Anything is possible with time, money and inclination.
Assuming the CLK is a facelift 209 version (given that its 2005) then pretty much nothing electronic will work. The systems are completely different.
It must be a 209 and I was looking at retrofitting things like front seats, rears if it's possible, headlights look similar aswell just wasn't sure if anyone had fitted anything from a clk to w203 thanks for your help
The front seats 'might' fit, the rears wont because of the difference in body shape. The lights may look similar but again unless you can check part numbers and see that they are interchangeable, you are opening a can of worms.
I'll have to measure them up and see if they will fit and I'll check the part numbers, thanks
