giusepppe
As soon as I start driving, I get a rhythmic sound coming from under the car, I have checked all four wheels for damage, or a nail in the tyre, any ideas what it could be. thanks in advance for any ideas.
.....Rhythm is gonna get ya.....Could it be a Gloria Estefan cd?
I'll get my coat...
The Eagles on my S204 do this if it's been sitting unused for a while. A few miles running makes them round again.One thing that's easy to check is if your tyres have gone 50p piece shaped. You can run your hand on the inside edge and can feel it. Ive had that before and it sounds almost like a wheel bearing. The older Eagle F1 tyres were quite prone - i can't remember the specific reason now but something to do with how the suspension loads the tyre. (Not related to incorrect adjustment)
Ah interesting - what ive experienced is actual wear. You can feel like a saw tooth profile as well, with a good few cm between teeth as it were. The Alfa used to be really prone on the rears, im not sure if its anything to do with the rear wheel steer.The Eagles on my S204 do this if it's been sitting unused for a while. A few miles running makes them round again.
The propshaft will still rotate while rolling in neutralput the car into neutral whilst it is rolling, see if the noise stops - try to separate prop shaft rotation noises from axle based rotation
The propshaft will still rotate while rolling in neutral![]()
Erm?....no. As a fellow ALFA man you have not thought that through!.....not only will it still be turning in neutral, it will be spinning way faster than the S Class one would be........You would have to roll along in neutral and switch the engine off to stop driveshaft rotation.Not on my Alfetta it didn't - the transmission was in the rear sharing housing with the diff![]()
Nope, it would be at idle speed..not only will it still be turning in neutral, it will be spinning way faster than the S Class one would be........
Yeah, I know. And in neutral, foot off the gas, it would be rotating at idle speed.The Alfetta one rotates at crank speed!
