The heater fan in my 2009 S211 has begun to play up in the past few months. When starting the car from cold, the fan runs as normal blowing air, but then will shut off for a seemingly random period. The control panel seems to have no effect on bringing it back to life, then magically after an unknown period of time it'll come back. This may repeat itself a couple of times, before settling down and working normally for the rest of the journey (as long as the journey is > 30 minutes long, it seems).
The temperature coming from the vents is exactly what it should be so I guess it isn't the duo valve at fault here.
I've replaced the fan itself and tried a new resistor, however neither cured the issue.
I've since followed the diagnosis guide on Pelicanparts, connecting an oscilloscope to the connector coming from the HVAC control panel and can see that indeed the control signal does appear to die and return at random.
Has anyone experienced such a fault before? Am tempted to get a HVAC control panel from ebay and give it a go, though there appear to be many versions of them!
