zendog66
Hello everyone,
I'm hoping to find a recommendation for a scanner / diagnostic tool for my W447 (2016) Vito van. I can't find one from a UK supplier that lists the W447 model as a supported vehicle. I was favouring a icarsoft MB V2.0, given its good reviews, but it only lists up to the earlier Vito W639 model. Its difficult to determine whether it will work at all with the W447 model. Ultimately, I'll buy whatever ~£100 scanner will work on the W447.
I'm hoping to diagnose an ABS plus Traction Control warning light problem that I have. Both warning lights come on together at unpredictable times whilst I'm driving, sometimes with the brakes feeling like they "catch" slightly, or a slight change in revs if I've got cruise control on. The lights will then stay on (with cruise control becoming inoperable) but will often reset after the ignition has been turned off and stay away for a while. It seems likely to be a wheel speed sensor/reluctor ring issue so I'd like to use a scanner to work out which wheel to focus on.
Many thanks for any help or recommendations you can give.
