Iskapsts
Hi guys, some advice would be appreciated,
Drive belt snapped and I was confident that an ac pulley as it tend to give out sounds consistent to bearing failure, however it turns freely and quiet as other drive belt components except water pump, I grab it both hands and lot of force was needed to turn it just an inch either direction, googled that new pumps might be stiffer, but not used one should roll freely.
Put new drive belt on, at first start pump didn’t move and belt started to smoke, but then after further 10 starts it goes well, removed belt again to check and it’s still stiff as no way that to be normal.
Any advice could that be pump itself or impeller I have no idea as never had touched water pump on this.
Many thanks.
Many thanks.
