190 2.5-16 Cosworth with the self-leveling rear end. 1991 car with 140k.
Rear end has become harsh over bumps, squeak from near side damper and feeling of 'movement' under cornering.
I have looked at bushes, bearings, links, etc-all ok, So I am now thinking dampers(look origonal), spheres, valve(where is valve by the way?)
1. So how do I work out which it is?
2. Or is this a damper+spheres+valve all together type job?
3. Is there any strange techniques to changing the dampers-I have seen a post about changing shperes)
4. would normal dampers make any real difference?
Many thanks for your thoughts guys!!
cheers Chris
cheers Chris
