I've just started having shift problems with my automatic C250TD (722 transmission).
Recently it refused to start when in Park. I suspected the shift interlock immediately, shifted it to Neutral and it started. This only happened once.
However, a couple of times it has refused to notice that the shift is Reverse - and it stays in Neutral. As soon as I move from R to P and back to R, all is OK again.
I'm going on holiday shortly, and need advice!
Anyone had a similar problem? If the shift interlock fails suddenly, how do I start the car, e.g. shorting out some pins on the interlock assembly? You can PM me if the advice would help a thief!
Regards,
Tim
Regards,
Tim
