Hi guys,
I have an issue with my car and was wondering if anyone else had come across it and had any ideas if I could start and drive my car without having it towed.
I have kept my car garaged for a while and left on trickle charge. I would usually start the car every few weeks but on this occasion it has been a lot longer than this, perhaps a couple of months.
Anyway I went to start the car today and when I turned the key the dashboard went red and said ABC car too low. I checked the car and sure enough the rear of the car seems to be lower than the front (both the rear left and right look equally lower than the front). I can not get the car to start at all, I tried disconnecting the batteries hoping it would reset itself but that has not done anything.
I would be surprised if the struts are damaged as they were replaced along with the pump around 10,000 miles ago - but of course this could be the culprit. I can not see any leaking fluid anywhere but admittedly I do not have very good access given that the car is low. There could be a leak but I cannot seem to see anything at the moment.
Also, I find it hard to believe that 2 struts would both fail at exactly the same time. Could be, but I think it is unlikely... I think the error message mentioned ESP as well, could it be an electrical issue?
Does anyone have any ideas as to what it could be and how I could fix it? Any help would be greatly appreciated!
Thanks all
Thanks all
