Help. looking for hard top stand for 91 sl 500. or could someone post phtos and dimensions for me, then i try and make one(did metal work @ school hope i can remember how. thanks STONEAGE
Thank for ur sugestion; found one on E,bay Its a universal stand ,which also has a cover for hard top, but items came off 98 300 sl. WILL THESE ITEMS FIT A 91 500SL Thanks again
Yes, hard top dimensions didn't change on the R129 (although the panoramic one is heavier and balances slightly differently).
Cover for the hard top is a good idea, mine lives in a padded bag (which is actually designed to be hung on the garage wall rather than using a stand). Make of my bag is Auto-Pak ... they come up on eBay sometimes.
Hi Bill, just wondering if you can tell me when the soft top is up can you see the metal struts holding the top or are they in a casing do you have any photos. Thanks Reg.
It shows 3 on the dial, I think. Only ever drops (slightly) below that when idling and hot. The handbook says what the pressure should be, from memory it's permissible to go down 1 at idle so long as it increases instantly the revs go up.
