Sl roof twitching noises
karozza
MALTA
SL55 AMG/C180 K
Which spray lubricant may I use to eliminate slight jerky twitching noises coming from the roof when closed??
I know this may not be a help, but I have the same problem. I took it into my local MB and they said, and I quote "as its a convertible hard top, you are bound to get noises like this. If you want it sorting, it will be a 3-4 hour job to strip the roof, find the noisy part and lubricate it. So I think you will be better off just living with it."
Great help.
If you find a solution, please let me know!!
That will certainly help with the rubber seals and may well be worth giving a try.
I think though that these roofs are inheritantly rattly - this was a criticism many motoring journalists brought up when first launched IIRC.
Which model of SL is the OP talking about?
There is a silicone lube available from MB that fixes this issue. Just wipe it on the seals.
I've heard various brands have these squeaky noises from hard top convertible tops & a lubricant does exist. I will try & find it or look up what is recommended on here
Our SL roof doesn't make any noise at all and all I use is 303 aerospace protectant on the seals.
Where can I buy this protectant on line??
Better still; which one do you use??
JRH30 said:
I use Wurth Rubber Fit.
Does it eliminate most of the creaking?? Also, does it last??
Was recommended to me. Dont have any creaks so more a preventative measure but have only been using it a few months. So far so good.
Karozza, how did you get on with this?
First, I sprayed Gummi Pfledge from Wurth, then 303 Aerospace on the rubber seals. After that, some ordinary grease on the locking/latch roof mechanism.
Now, no more squeaks or twicthes :bannana:
