Ok ive recently bought an SL500 2003 model and put a nice set of 20" brabus wheels but the car was far too high up.
I invested in lowering links which are easily changed and can lower the car to your desired height
Now the car has a button with 3 settings
1) lowest low height
2) medium ride height
3) highest ride height
I have been driving on no2 as it was enough clearance from the wheel to the arch.
Ive had no problems changing to the adjustbale links over the past 2 months but the other day my car would not raise from the rear and the 'ABC' warning came on the dash ' ABC please visit workshop'
I have put it on a diagnostics machine and two code errors which have come are P2003 and P0410 not sure if these have any concerns to why the rear does not lift and only the front.
Now when I start the car , the car drops down to its lowest setting and I would normally press the button once to put it to no2 the medium ride height and the car would lift front and back now only the front lifts.
Once i switch the car off nothing happens only drops once started, also once the ABC warning appears again (once you drive over 20mph) the entire car lifts up to its maximum height so weird!
So im not sure what it could be either a dodgey switch in the car? or a leak? or loss of pressure?
The system may need bleeding but any suggestions guys?
