My sprinter 416 2.7 cdi has a starting issue. Will start first time wont rev or will cut out. Then will start and immediately cut out. This first started as a power dip but has gotten as worse as it is now. It did run fine and would cut out if revved over certain revs.
No fault codes, no bubbles in fuel lines, filter replaced still the same.
Wjat ive noticed is that the alternator light is coming on and off and then stays on then it cuts out.
