Greetings all
Greetings all, can anyone help please? (sorry for this long thread)
The Airmatic damping on my immaculate treasured W220 'S' is (always has been) super-stiff at all 4 corners (front to rear, side to side and diagonally). The car runs on standard 17" alloys with OE 225/55 x 17 Continental tyres at the correct pressures with no mods to the suspension, but even low speed minor road ruts and ridges send severe jolts through the cabin as if the entire system is permanently locked into 'safe' (stiff) mode and not releasing / adjusting pressure to the struts according to the conditions. My best analogy is that the car rides (or rather bounces!) over even minor road imperfections like a skateboard.
History: well maintained 2004 car with 120k miles, mine since 2016. Airmatic compressor and relay replaced at 60k miles, 2 x recent 'STAR' diagnostics not showing any fault codes, suspension doesn't lose height when parked up (so leaks not suspected), maintains correct ride height always. Dashboard switch raises / lowers height correctly, but Sport 1 & 2 settings are inoperative although the lights come on. No wiring faults found on recent physical examination, no Airmatic warnings on dash, so I'm completely baffled.
My Question(s): could the problem be due to a faulty / seized valve block (but which for some reason is NOT showing any codes?). Or, similarly, the pressure relief (release) valve in the compressor? So far, 2 Merc Indies haven't solved the problem. All they say is: "the struts actuate ok and we can't see any fault codes on STAR". Mmmm...
Also.. just after buying the car there was a temporary burning rubber smell in the cabin - as if some wires had shorted. Again, is it possible that an electrical / wiring fault might NOT show up on STAR - or at least when the vehicle is stationary?
On another forum there was some mention that the ADS solenoids attached to the struts at all 4 corners aren't getting the correct voltage - and so the ADS system ECU is defaulting to the hardest (of 4 - hard compression and hard rebound) settings in 'safety' mode. Had these tested yesterday with a (non-STAR) OBD scanner when the car was stationary (as opposed to on the move), but it showed that all 4 were drawing current - and no fault codes / dashboard warnings thrown up. So the plot thickens...
All thoughts, advice and experiences welcomed to restore the 'magic carpet' ride that the S Class is famous for - many thanks!
MB
MB
