IFFY100
Basically I've been renewing suspension items that require to be refreshed with Lemforder/sachs parts. So far I have done the following in terms of the front suspension: sachs struts/oem springs, sachs top mounts lemforder thrust arms and lemforder ball joints and lemforder suspension arm (the arm the strut, drop link and hub ball joint bolt to). The last two parts I changed where due to play in the BJ and tearing in the arm bushes. The car would noticeably move left and right after going over a bump. The movement was down to the torn bushes. Now doing all this and having a four wheel alignment done (proper professional), there seems to be a bit of twitchiness in the suspension. This time though the wheel does not feel like it is moving sideways over bumps. So I'm thinking that the movevement in the suspension is because I tighetened up different parts and those parts are now exposing weakness elsewhere. This being the case, which part should I look at to change now? Or investigate? Tie rod ends seem to be fine
