Hi guys,
Please can you help with few questions about suspension.
I recently had the following done at mercedes as I had some annoying rumbling noise coming from the drivers side suspension area:
The items that were replaced on your Mercedes were the drivers side top ball joint (A000 330 10 07) the drivers side bottom ball joint (A211 330 04 35) and the drivers side lower suspension arm, along with it's fittings (A211 330 44 11)
Cars just had mot and aparantly the tie rod end bearing has play. Am I right in thinking this is different to the above work that was carried out?
Rob
Rob
